305tpi to 350tpi
Old Jul 31, 2007 | 10:16 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
305tpi to 350tpi
I've done a search and found most my answers, but just want to make sure I'm understanding this right. I have an 88 camaro with a 305tpi/auto. I'm looking into picking up a 350 (l98) short block and heads out of an 86 corvette. From what I read my Tpi intake wont bolt up to these heads, and neither will my serp. pulleys. I found a guy seling the 083 heads off his 89 350 l98. Will these bolt right on to the short block and allow me to use my tpi and pulleys off the 88? Also what year computer (ecm) would I want to use? And from what I've read 86 corvette l98 motor are non-rollar blocks, is this correct? Any help would be great, Thanks Jay
Old Aug 2, 2007 | 03:01 PM
Car: 94 25th TA
Engine: 355LT1
Re: 305tpi to 350tpi
Anybody???
Old Aug 3, 2007 | 12:15 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
'86 was a changeover year for the heads on a Corvette. Some will be aluminum, but most will be iron. Either way, they will be the old-style intake bolt angle, so your '88 intake will not bolt up the inner four bolts.
Yes, 89 f-body heads will bolt right on, as GM used the same 14101083 heads for all 87-92 f-body 350's.
Yes an '86 Corvette block will be a non-roller, but will have the one-piece rear main seal like an '87+ roller block.
An '86 Corvette and '88 Camaro should use the same 7165 MAF computer, so you can use whichever.
Old Aug 5, 2007 | 01:24 PM
Car: 94 25th TA
Engine: 355LT1
Thanks for the help
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
rdog30
Apr 6, 2001 07:07 PM
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
