chaged thermostat now code 33
Old Aug 1, 2007 | 11:40 AM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
Changed thermostat from 180 to 170.
Car ran fine beforehand...
Now she throws a code 33 while im driving around 30-40 mph
The idle is also higher
I did take off the TB and took off some of the the air intake but im checking and checking it and spraying with wd40 dont spot any leaks..
I did unplug the battery and let her reset and it still did it
Old Aug 2, 2007 | 11:02 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: chaged thermostat now code 33
did yopu check the wire in your MAF? could be broke or loose connection. 33 is for your MAF sensor. did you reset your TPS after you put the TB back on? Reset it, it could be your problem also. check your IAC as well. since you removed the TB you may have to reset everything on it.
I had a similar problem last month and a new TPS fixed the codes I had, 33 was one of them. try to reset the sensors first b4 replacing them.
Old Aug 2, 2007 | 02:28 PM
sting's Avatar
Car: '87 TransAM
ahh yes, the tps wasnt adjusted right, i didnt know taking the tb off screws it up, seems to be fixed, thanks
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
