search for egr is giving error..... help
Old Jul 29, 2007 | 02:20 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i tried searching for egr but it kept giving me an error......
my problem is that i have an egr code, what are the basic steps i should take to diagnose it? does anyone have a list of steps? thanks!
btw the egr is new, the intake is clean...... thanks
Old Jul 29, 2007 | 06:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Re: search for egr is giving error..... help
1989 should still have the EGR temp sensor screwed into the base of the EGR valve. Did you transfer it over to the new valve? Is it plugged in? Check all of your vacuum lines, make sure you have vacuum up to the solenoid.
Old Jul 29, 2007 | 09:42 PM
bigchief's Avatar
i'm pretty sure i have vaccum but how do i check it? do i have vaccum ONLY when the car is crusing??? then how am i supposed to check it?!?!
Old Jul 30, 2007 | 07:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Hook a gauge up and tape it to your windshield.
Old Jul 30, 2007 | 08:12 AM
bigchief's Avatar
lol alright, i guess thats the most direct way. so lets say its getting no vaccum at all, i know from the egr it goes into something that gets vaccum from the bottom of the throttle body. i know that the throttle body is getting vaccum, so where could i get that piece that the hoses go into since its probably the thing leaking?
Old Jul 30, 2007 | 08:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Try your favorite parts store or the stealership. Never had to buy one of those before.
You may have to buy the whole solenoid.
Old Jul 30, 2007 | 01:11 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
There is a test procedure outlined in the Haynes/Chiltons/Helms/Shop manuals. I just went through it with my car (92). If you really need it, I'll try to scan it for you...
Old Jul 30, 2007 | 03:29 PM
bigchief's Avatar
that would be really cool if it applies for the my car too, its probably the same thing right?
Old Aug 1, 2007 | 11:10 PM
RandyJ75's Avatar
Sometimes, a lack of back pressure will cause the computer to set a EGR fault. I see that you run headers w/ no cats. Could be the reason.
Old Aug 2, 2007 | 04:51 PM
bigchief's Avatar
hmm wow i never even though of that wtf.......
Ghettobird52
Jul 5, 2024 11:18 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
