Fuel pump bleeds down
Old Aug 1, 2007 | 09:35 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
Fuel pump won't energize with key after it sits for three days or more. If the car is started more often it starts and works fine. Put in new fuel pump relay and have had mechanic check wiring and replace ignition switch. He suggest wiring a switch to energize it when needed but that seems cheesy.
Old Aug 1, 2007 | 10:56 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: Fuel pump bleeds down
Why dont u find where the problem is?
Put a fuel pressure guage on it, block the return and feed lines and see if it holds pressure. If it holds pressure, release the clamp on the feed line and see if the pressure drops. It will tell u whether the injectors are leaking down or the check valve in the pump is bad.
later
Jeremy
Old Aug 1, 2007 | 11:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're saying the pump won't prime when you turn the key on after the car has been sitting without being started?
Old Aug 2, 2007 | 11:50 AM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
Apeiron that is exactly it. Any ideas? 3.8 thanks for the idea, the car is currently in Colorado and I am in Wisconsin trying to give my mechanic ideas.
Old Aug 2, 2007 | 11:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What kind of shape is your battery in after three days?
Old Aug 2, 2007 | 05:40 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
Battery is very new and cranks the car very well. The fuel pump acts like it is not getting the signal after it bleeds down.
Old Aug 2, 2007 | 06:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you don't have an electrical problem supplying power to the pump, then it sounds like its time for a new pump.
Old Aug 3, 2007 | 07:17 AM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
I think that may be it, it just sucks so bad to it, I did one in my last car. I want to be sure before I did it again. Is that Petronix one the best one to get?
Old Aug 3, 2007 | 09:32 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I haven't read here anything about troubleshooting the fuel pump circuit. Is the mechanic sure that the fuel pump is not getting power? Has he checked the tan/white wire on the fuel pump relay for voltage during the 2-second fuel pump prime?
There is more to the fuel pump circuit than the relay.
Has the mechanic checked connector C313 above the differential?
Lou
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
