How to - Ohm Injectors
Old Aug 2, 2007 | 01:48 PM
wolverine350r's Avatar
Car: 91 TA WS6
Transmission: Auto :(
I searched and couldn't find a simple description of what to do. Do I just unhook it from the harness and put and ohm meter across it? Also, the previous owner said it has Ford Racing 24# injectors, should they be the same ohm reading as I see posted everywhere (14-16 ohms)?
Old Aug 2, 2007 | 05:55 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: How to - Ohm Injectors
If their svo injectors 99-1 they are not bad (it can happen but rare)
Undo the inkector plug and put the meter between the terminals.
14-16 is stock injectors
All svo I have had see worked with were nearer 17.
Anything below 12 is junk per GM.
Ohming them only verifies the electrical side however, you could still have issues with the injectors themselves
Old Aug 3, 2007 | 12:08 PM
Car: 91 TA WS6
Thanks for the reply. All I know is I was told they were newer 24# Ford Racing when I bought the car early this year, I did check them and they were all 15.5 or 15.6. I just thought I would give that a try to check easy things.
I think my real problem is the ICM or coil, as the car dies after operating at 220 in stop and go traffic for a few minutes. Then it will start after sitting for 5-10 minutes.
Old Aug 3, 2007 | 12:27 PM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
look at the distributor module.........
Old Aug 3, 2007 | 02:15 PM
Car: 91 TA WS6
Yeah, the ICM is the module I believe you are referring to in the distributor. I took the cap off and it looks pretty old (maybe even original), looks like the car is due for a new cap and rotor also.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
