injectors going in tomorrow... got any handy tips?
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
i got my 19 lb ford injectors in the mail from jegs, $209 plus tax and shipping to $235. not a bad deal... i'll be tackling this tomorrow.
plenty of you guys on here have swapped injectors enough, do you have any tips? horror stories? etc? it'll be my first time doing it so combined with the instructions, any tips or advice would be awesome
i'll be using the instructions on www.thirdgen.org/injectorswap
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Re: injectors going in tomorrow... got any handy tips?
Make sure you have a right torx. I hate TORX. Just be careful. Open up the gas cap to relieve pressure, have something around to catch any fuel coming from the main and return line. Stuff like that.
I haven't done it myself. I had the manifold apart, put injectors onto runners, but never did it together (I worked on few cars at different time LOL). You can hear the snap when the injector seats properly into the fuel rail and the intake. If you don't get it its most likely not in.
Good luck, it shouldn't be a hard job. Just takes some patience to be done right.
It was a real pain to do them the first time in my 92 Z28. Take your time and make sure you have lots of extensions and swivels. Some of the bolts are terrible to get to. Also be very careful not to damage a gasket when you are putting it back together.
Leonard
Leonard
Car: 1986 2.8 Camaro
Engine: TPI 350
Transmission: Tremec TKO
The mistake I made with mine was not using new gaskets, when I put it back together. I now have a vacuum leak, thats making my Camaro run like poo-poo.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
put vasoline on the o-rings of the injectors before goin in... helps alot.yea the TPI has like 6 gaskets lol u have a good chance of messin that up.... make sure theyre set when goin in maybe even use some goop(permatex) to hold it in place.
Andrew Prakash
Sep 8, 2015 11:48 AM
