Good sized injectors
Old Jan 8, 2001 | 07:17 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
What is a proper size injector for an engine creating around 650HP?
36lb/hour?
1986 Camaro
Carbureted 305
700R4
Old Jan 8, 2001 | 09:22 PM
Kyle F's Avatar
30lb/hr @ 55-60psi and .42-.45BSFC
36lb/hr too many to list
if you want it to be easy to tune go with the 36lb/hr you only need to run 40psu
the source of this is GM Hi Tech Performance Jan 98 issue. If you would like the cahrts email me at Kfelts@zoomnet.net and I will scann them for you
Old Jan 9, 2001 | 09:16 PM
TAMECH's Avatar
A book I have says multiply horse power by .45 then divide by 8, use .55 if you are using supercharger.
1987 T.A.
4 bolt 40 over MSD 6al BBK/EDL throttle body Accel coil, wires Compu Cam Roller roc K&N filter Jet custom chip Removed screens and cooling fins on M.A.F. Ported Corvette heads 700r4 shift kit 40+ 4th gear 2300 stall Stock GTA rims with 255/50/16 rear 245/50/16 front Z rated comp ta's
Old Jan 9, 2001 | 10:58 PM
Kyle F's Avatar
the numbers I have are Dyno results and calculations
Old Jan 10, 2001 | 10:26 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
What system are you planning to use EFI on? With SD or MAF, large injectors require very short pulse widths at low rpm which can cause a problem.
Also high impedence injectors like the TPI system have limits on the size of "affordable" injectors. Larger injectors are available, but get expensive.
Old Jan 10, 2001 | 02:31 PM
StCr19's Avatar
Old Jan 10, 2001 | 07:00 PM
Car: Death Mobile
Engine: 666 c.i.
You might want to post this question on the PROM Board and ask "Will I have problems with TPI making 650 HP"?
I believe you will find a problem with the short pulse widths for idling, 650 HP will probably cause the MAF system to max out to 255 gm/sec at relatively low rpms, and SD probably will have problems with a low MAP.
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
knight72
Aug 10, 2015 09:32 PM
