Swapping from EFI to a Carb in a Thirdgen
Old Jan 10, 2001 | 08:08 PM
LmpBzkt's Avatar
I have a question about removing the computer from a TPI setup when swapping to a carburetor. Doesn't the Computer control the fuel pump relay, and if so, how doo you get the fuel pump to kick in when it is supposed to? Thank You
Old Jan 11, 2001 | 02:10 AM
TAMECH's Avatar
If you are getting rid of your TPI, I will express mail you a carb for it,what the hell I will throw in a intake also.
1987 T.A.
4 bolt 40 over MSD 6al BBK/EDL throttle body Accel coil, wires Compu Cam Roller roc K&N filter Jet custom chip Removed screens and cooling fins on M.A.F. Ported Corvette heads 700r4 shift kit 40+ 4th gear 2300 stall Stock GTA rims with 255/50/16 rear 245/50/16 front Z rated comp ta's
Old Jan 11, 2001 | 11:56 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
OK, first of all can we say S T U P I D!! WHY would you want to swap TPI for a carb! Not only are you gonna lost LOTS of Gas Mileage, you will also have fun in the winter starting the car! There is ZERO advantage to swapping so why do it?? If you really want to swap, I'm like the last guy.....you send me the TPI and I'll send you a brand new 600 or 750 Edlebrock carb your choice!! 2nd...IF you are swapping to a carb (poor guy), you CANNOT use the TPI fuel pump!! A TPI fuel pump, pumps around 40PSI.....a carb/manual fuel pump, pumps around 4 PSI!! IF you do swap to the carb, you will have to disconnect the computer, the fuel pump relay, and disconnect the oil pump guage and switch to a mechanical oil guage! And of course put in a manual fuel pump! You can leave the electric pump in the tank....it will not cause a noticeable restriction in fuel flow! I hope this help but GOD MAN, DON'T SWAP!!
1986 Trans AM
305 TPI
Completely Stock
Soon to upgrade to a 327 TPI with pocket ported 64CC heads, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
beachrodder
Aug 25, 2015 08:05 AM
