New Accel fuel injectors for $230. questions!
Old Jan 10, 2001 | 12:11 AM
My Slow Iroc-Z's Avatar
These are the brand new ones Accel came out with that cost half as much as the older style. I was thinking of picking up the 24lb/hr set instead of getting my stock one's cleaned. Now I know that L98 injectors are 22lb/hr assuming that these Accel injectors are rated at the same presure as the stock GM injectors, if someone knows that they are rated at a different pressure please speak up, what will I have to reduce my fuel pressure to so I don't run rich.
Glenn91L98GTA if you reply to this post, I know that you always recommend buring my own prom but I tried reading up on all this prom stuff and it is way to confusing....
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, 3.8L Turbo V6 200* fan switch, MSD GM coil, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 oil, and more to come...
Best ET not corrected- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
Old Jan 10, 2001 | 12:42 AM
noam's Avatar
hey what's the Part # on those suckers, i think i'll be ordering them myself hehe.
Old Jan 10, 2001 | 03:45 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
There is a thread on the Corvette forum under aftermarket parts. I think you will find what you are looking for there.
http://www.corvetteforum.com/
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jan 10, 2001 | 03:53 PM
Scott C's Avatar
I spoke with Rich at Cruzin Perfomance just last week about those injectors. They are not available just yet. It appears that Accel had a slight delay in the engravement process of the injectors (each injector will have the #/hr engraved at the top for easy identification). There will also be odd sizes available to fill in the gaps where no injector is currently available (20#,23#,25# etc.). No custom prom burning required here!!
I'm looking forward to recieving my set from Rich in the near future!
Old Jan 10, 2001 | 11:11 PM
Summit part number is ACC-150824 for the 24lb/hr injectors and cost $230. ACC-150819 is the 19lb/hr ones for the same price. ACC-150830 is the 30lb/hr and cost $250
Old Jan 11, 2001 | 01:16 PM
Scott C's Avatar
If you looked at the Summit website, you'd see that those part numbers are not in stock.
Old Jan 12, 2001 | 02:34 AM
Yeah, I know they are not in stock yet but I was just giving out the part numbers because someone asked.
Old Jan 13, 2001 | 10:05 AM
noam's Avatar
the last 5 things i ordered from summit were not in stock and within 4 days they were on my doorstep, you just gotta call cuz they are rare requests.
bryan623
Mar 22, 2021 06:43 PM
tazs2000
Jul 15, 2017 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
