I have a 355 tpi with a procharger. Should i go MAF or SD?
Thats it, nice and simple. I dont need an explanation, just what you think. Its a 1988 Firebird Formula with every imaginable mod and the cam is pretty mild 452/465. BTW, it has 24 lb injectors. Do i keep the MAF, or go to SD? Thanks guys, youre great.
"Restore decency in America. Ban rice!!"
Moderator at www.Lastgen.com check us out!!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Since you already have MAF, I'd keep it. I only recommend using SD if you have an 85 TPI, or if you're switching from carb/TBI to TPI.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Formulagod....have you any dyno runs? What is your set up? Mail me!
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Car: Death Mobile
Engine: 666 c.i.
The problem you will have with an SC is that the MAF will max out at 255 gm/sec and the 165 ecm that you have will not be able to compensate.
But going to the SD with the 730 ecm will not help either. They only have a 1 bar MAP sensor so you will have the same problem. Yes, you can make adjustments to the WOT values in the VE table, but it is "guessing". You can do a similar thing for the MAF 165 ecm; again you will be guessing.
From what I understand, the only real effective way (that is fairly easy to convert) is to go with the ecm off a Syclone/Typhoon. They support a 2 bar sensor. Ask "What is involved in converting to a Syclone ecm" on the PROM board if you really want to convert to an ecm that can handle boost.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
