stock advance curve
Car: '89 GTA
Engine: ZZ6TPI
stock advance curve
What does the timing advance curve look like on a stock L98. I know it starts at 6 degrees at idle, but what is full advance and at what RPM is it all in?
89 Transam GTA, a few bolt ons
Car: 89 IrocZ
Engine: L98-ish
Probably want to ask on the PROM Board for the exact curve, but advance is governed by a few different inputs the ECM sees....but on flat ground, from a standing start, mine will get about 32* BTDC at about 2500 or so, IIRC, last time I looked was when i had my scanner plugged in, and just sorta glanced over at it.
