Vacuum Canister Removal with DFI?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I know what you are all going to say, I should leave it in there, but this is one case where it is not a good idea. I have switched over to a DFI unit that replaces the stock computer and there is no provisions for it. Therefore it is inoperable. The electrical plug that goes to it controls a valve to open and close but now there is no signal so it will not work right? How do I make a venting system so the tank does not build up excessive presure? Anyone done this yet?
Steve
Steve
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I left mine. Haven't had any problems in two years. You could always go to a vaccume operated unit like on the older cars.
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
My car's homepage
Just run a vacuum hose from the tube that is coming from your fuel tank. Run that vacuum hose to below your car, so any fuel/fumes will be vented there. I had it setup like that with no probs. But my smog hook up went bye-bye, and I had to put everything back on.
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Better yet, put a cheap .99cent Napa fuel filter on the vent line then run it down under the car. Mine has been like that for 3 years. The only thing you DON'T want to do is plug that vent line!
86CamaroDan
Sep 29, 2015 10:08 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
