miniram and MAT sensor
Old Jan 17, 2001 | 08:06 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I don't understand how the MAT sensor can be relocated before the throttle body. Are you supposed to just relocate it to the air cleaner assembly by drilling a hole a tapping threads?
'89 Formula 383 TPI
Old Jan 17, 2001 | 09:16 PM
87Z-ya's Avatar
You hit the nail on the head.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Old Jan 17, 2001 | 11:05 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I have my relocated MAT put in rubber boot just in front of the TB. I talked to TPIS at the time (I too was going to put mine in the air cleaner assembly) and they did not recommend it. They said there isn't good air flow and that the boot directly in front of the TB was a better spot. Also, any metal will conduct heat to the sensor.
One suggestion, do not remove the stock MAT or pull out the wire. Only swap the connector at the harness near the rear of the engine. You may find there are situations where you prefer the stock MAT. Currently, I cannot use a relocated MAT during cold weather; causes the ecm to over richen the car.
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
