Lots of carbon deposits in TPI parts, normal???
Old Jan 19, 2001 | 02:26 AM
Dan87IROC-Z's Avatar
I took the TPI pleunum off and there was lots of carbon soot covering the insides of it, is that normal, whta does it mean, can I fix the problem.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 19, 2001 | 03:33 AM
93ND500's Avatar
Yes, it is normal. That's provided that you are still using the EGR system.
Old Jan 19, 2001 | 01:09 PM
Guest
Guest
Posts: n/a
Completely normal, even if you ditch the EGR. Its not quite as bad, but still there. The reversion from the wonderful design of the TPI forces some fuel back up the manifold. A tradeoff for a 'tuned' system I suppose.
Old Jan 19, 2001 | 05:41 PM
Thanks a lot guys, I was kinda worried when I saw all the deposits.
L98 TPI 350 (5.7L)
jaridjohn
Jul 8, 2024 03:49 PM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
