searched.. no dice, weird idle issue
Old Aug 10, 2007 | 09:33 AM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Hello, motor in question is an 88 L98
Car will idle at 900, then slow to 600-500 (sounds like a/c comes on) then goes back to 900.
IAC cause this? its not constant, but every 5-15 seconds will go from 900-5-600 and back.
Old Aug 10, 2007 | 11:37 AM
PurpleHaze92's Avatar
Car: 1992 rs
Axle/Gears: ones that turn
Re: searched.. no dice, weird idle issue
Mine has the same issue, mine also sounds like it's "gulping" air when you blip the throttle.
Old Aug 10, 2007 | 01:44 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
apprenty when dad pulled IAC connector off, runs AWESOME and smooth and idles at only 900 :S
Ill leave it off
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
