Who makes SVO injectors and what makes them better than Accel?
Old Jan 26, 2001 | 12:18 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, who makes these SVO injectors that I keep hearing about and why should I go with them as opposed to Accel injectors??? Where can I get the SVO injectors and what is the approximate cost of a set of 24 lb/hr injectors?? I'm really thinking about going with the Accel injector GP but I'm still open to advice!!
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, 64cc Pocket Ported Worlds Product Sportsman-II heads, ported intake, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Old Jan 26, 2001 | 01:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
SVO stands for Special Vehicle Operations and its a Ford trademark. On Ford vehicles with 37 PSI they flow 24lbs but on GM vehicles with 43 PSI they flow 26lbs or so. People like them because they are usually cheaper, and they're good quality.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 26, 2001 | 02:05 PM
88irocz's Avatar
Kevin,
Do you know the calculation in determining that statement? (the 24# injector flowing like a 26@43psi). I would appreciate if you could help me out.
Old Jan 26, 2001 | 05:55 PM
Kevin91Z's Avatar
No, I dont but somebody does. Try searching this forum, maybe its been posted before.
Old Jan 26, 2001 | 07:07 PM
a73camaro's Avatar
new flow = old flow * (new pressure/old pressure)^0.5
Or
New flow is equal to the old flow multiplied by the square root of the ratio of new pressure to old pressure.
Old Jan 26, 2001 | 09:47 PM
Scott C's Avatar
Uh.....WHAT? =0
Old Jan 26, 2001 | 09:48 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
What A73 said.
tazs2000
Jul 15, 2017 08:44 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
