Fuel presure
Old Aug 13, 2007 | 12:14 AM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Fuel presure
I have a 91 355 TPI camaro. and I wanted to know how to check my Fuel pressure regulator. I swapped out the TBI for the TPI so I couldnt get the pump to run, so I just put it on a switch. So i put the fuel pressure tester and it reads 45 with switch only and 36-38 with car on. Ok so with the car off and switch only its 45 right? then I turn off witch it goes to 0 really fast. Is my regulator bad?, and how would I test it, or are my injectors leaking. Also my exhaust is making a popping sound and was wondering if that fuel pressure issue has anything to do with it. Help please having a local F-body club meet and car is not doing well. Here is my car http://www.cardomain.com/ride/2662904 It needs paint I know but the important part is the engine first and it aint doing good
Old Aug 13, 2007 | 01:03 AM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: Fuel presure
By the way my injectors read 18.5, is that good?
Old Aug 15, 2007 | 11:35 AM
91toplessz's Avatar
Car: 91, z28vert
Engine: tpi, lb9
Transmission: t5
Axle/Gears: ?stock
Re: Fuel presure
Hi, buddy! I did this test about 2 months go. block fuel supply line by pinching the hose quickly before pressure starts to drop. If holds its some thing in the tank. If still not holding then block the fuel return line by pinching the hose quickly. If it holds then its the regulator, guessing your lines under car okay.And if it dont hold then its injector. Did this to mine and the pressure held when i blocked the return line,replaced the regulator and pressure held after key off for hours. 18.5 is good. when my injector was bad it read like 8.5 and the others were 17,16. Im not a pro but hope this helps you some.
Old Aug 15, 2007 | 11:59 AM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: Fuel presure
thanks man that does help alot
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
