Fuel Canister relocate...HELP TECHS!
Old Jan 25, 2001 | 08:54 AM
Steve89GTA's Avatar
I'm trying to get as much cold air as possible into my car. I've got a scoop installed on the bottom of the car and I'd like to move the fuel canister out of the way so my 4inch tubing can fit nicer. Can the canister be mounted sideways?
Also, I was thinking of making a bracket and mouting it below the frame where it sat before since there is alot of room down there. I think it should be fine down below...any suggestions/comments?
I was thinking of enclosing it in a pot-light-like enclosure and securing it to the frame.)
Thanks in advance!
89 GTA
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
MSD6A Ignition
Accel Supercoil
Custom Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Jan 25, 2001 | 06:45 PM
Ron Mullins's Avatar
Check out my page and see what I did.
http://www.geocities.com/91formula
Click on My Ram Air
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, MSD6AL, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Jan 25, 2001 | 07:51 PM
MikeC.86Roc's Avatar
Try visiting this site and check out Bernard's cold air setup on his Trans Am. It's the featured ride. http://sethirdgen.org/
Old Jan 26, 2001 | 05:43 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I did an alteration that calls to cut the battery tray a bit. Works awesome. It howls outta the fenderwell when you first start the car quite loud.
Ron did a nice job with the scoop. Ron, did you re-polish your rims. They look great!
http://www.public.asu.edu/~zzz2628/G.../MODS/mods.htm
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
Old Jan 27, 2001 | 07:41 AM
No I haven't repolished my rims. Thanks though.
Ron
91 Formula WS6
Old Jan 27, 2001 | 11:43 AM
Guest
Guest
Posts: n/a
I am pretty sure the only thing that matters is that it remains vertical. I dont think it works right laying on its side.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mustangman65_79
Apr 14, 2017 05:37 PM
sailtexas186548
Aug 24, 2015 10:11 PM
