305 cam
Old Jan 27, 2001 | 04:34 PM
trubo ta john's Avatar
305 cam
can anyone recomend a good roller cam for a 305 tpi that gives good torque on the bottom end?
Old Jan 28, 2001 | 07:37 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
What RPM range do you want the torque to come on? If you are looking for a (stock type) torque start point of 2500 RPM with more upper RPM I would run a ZZ-3/ZZ-4 cam. The ZZ-3/ZZ-4 cam will pull hard from 2500 RPM to 5500 RPM.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Jan 28, 2001 | 09:02 AM
Nitro Don's Avatar
I think the MAX lift with the stock heads is about .450 lift.
Limiting you cam selection.Go with some aftermaket heads and put in a nice cam.
Im running Comp Cam 210/220 .533/.544(1.6)
I plan on swaping out to Comp's larger
TPI cam the 230/244 .544/.576(1.6)112LSA
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
