AFPR..... boy am i spooked:(
Old Jan 29, 2001 | 03:24 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
i just installed my crane afpr, and i can't help but be spooked by the local NAPA guy's comment that this thing is a fire waiting to happen . The install didn't go as the instructions said, dur to the fact the diaphram and spring all can off with the "cap." I checked both seals and they are fine. I tighened everything down , and have pressurized the rail for about 2 hours now (on/off with the key), and no leaks. HMMMMMMMMMM, I just don't want my 'ROC looking like the 3-4 i have seen in the yards. Granted many more are there with their hoods intact but.......... Guy's really need some confidence/ advice. I know a lot of you have had no prob.s and have even built your own. All encouragement welcome. THNX THE SHAGGY IROC
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Jan 29, 2001 | 03:40 PM
evilho7810's Avatar
I wouldn't worry if it isn't leaking.
Old Jan 29, 2001 | 04:03 PM
Guest
Guest
Posts: n/a
Start a fire where there isnt one... typical parts counter moron
I have 2 cars with AFPR's, one is I think an Accel, and the other is homemade.
Hitting send before Im done... silly
Anyway, one is 2 years old, the other is about 4. Neither leaks.
[This message has been edited by madmax (edited January 29, 2001).]
Old Jan 29, 2001 | 04:29 PM
thnx guys, to here success stories
Old Jan 29, 2001 | 07:16 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
lol, parts store guys are -sometimes- kind of like that. If you wanted to see a fire hazard you should of seen my manifold when i had gas covering a most of it and a resevoir (sp?) starting next to my valve covers. But they weren't due to the Fuel Pressure Regulator. Rather a bad bad leak. If i was you, just turn the key to the "on" position and go look under the hood for fuel leaks, if none, then yer good to go... If there was one, i'd hope you could smell it. I sure could.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Jan 30, 2001 | 09:28 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Wanna see a fire hazard? Look at the fuel line routing on a 4th gen! SCARY! AdjFPR on my 89RSZZ4TPI for about 4 years, no leaks, just seems to have started to freeze up a little.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Elephantismo
Feb 13, 2019 12:51 AM
85cmroz28
Oct 4, 2015 09:44 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
