corvette heads and intake for a 305 TPI
Old Jan 27, 2001 | 05:06 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
A freind of mine has parts from a late 80s vette.
He's giving me the intake set-up for free and the aluminum heads for like 50 bucks or so.Can I just bolt on the heads on o a TPI 305? And didn't the vettes have a different TPI set-up? Like a mini-ram or something? The thing is he's gotta dig it up from his personal junk-yard.He doesn't remember what it looks like.
Can I bolt on these parts on to a 305 w/out a problem? I imag8ine I whould get a nice performance gain?
Any help is appreciated.
1990 Formula
Fatory:WS6-TPI-305/Dual Cat/5 Speed.Aluminum Drive Shaft.
Mods:SLP air foil,K&N Filter,All Accel ignition parts,Hypertech Thermomaster chip,Stat,Fan switch.Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch.`
Old Jan 27, 2001 | 11:48 AM
Guest
Guest
Posts: n/a
Yea, it will bolt up to a 305. The intake isnt really any different on the vette. What you will run into is the EGR setup from the vette, which ports exhaust from the RH exhaust manifold into the back of the intake near the distributor since the heads do not have heat riser passages in them, and the center 4 bolts on the vette heads are the early style rather than the 87-up style. Since you are getting the intake, just swap the vette base onto your car as well. If you have to use EGR for emissions tests where you live, then hook up the port on the back of the manifold to the exhaust manifold. Otherwise I would probably just block that off. You will need a special head gasket for aluminum heads, and I think you have to use the 350 head gasket. Willie knows about that one.
Find out what year it is too, may have to consider if theres a cold start valve on the vette setup and may need to block that off too, Ive never dealt with it so Im not sure how that works out with later runners.
[This message has been edited by madmax (edited January 27, 2001).]
Old Jan 29, 2001 | 03:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its more than just running the EGR from the exhaust manifold to the intake manifold, because the f-body exhaust manifolds dont have anything to connect the EGR tube to! You'll have to fab up something like I am doing. But I'm modifying my SLP 1 3/4" headers, not stock exhaust manifolds. If I was you, I would put those parts away and save them for when you get a 350 engine.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 29, 2001 | 03:56 PM
Guest
Guest
Posts: n/a
Well yea, thats true... being picky on me!
Might be able to modify the AIR tube setup near the back to port EGR instead. If you wanna get technical you have to fab up a EGR tube as well
Old Jan 30, 2001 | 11:52 AM
Fastcamaro87's Avatar
350 heads have larger combustion chambers, if u put them on a 305 your compression ratio is going to significantly drop,
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Jan 30, 2001 | 12:36 PM
Guest
Guest
Posts: n/a
Not the aluminum ones, those are 58cc so the compression wont change.
Old Jan 30, 2001 | 01:25 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
You will have to use 350 head gaskets. Madmax is right about the combustion chamber volume. These are the only 350 heads (I believe) that happen to have the same combustion chamber volume as stock 305 heads, 58cc.
And why are you guys going to the trouble of fabricating an EGR passageway? Just bolt everything back up as though the heads have the passageways. I did this two years ago. I have yet to set any related codes AND I pass emissions every year with flying colors (visual and tailpipe).
Willie
[This message has been edited by Willie (edited January 30, 2001).]
Old Jan 31, 2001 | 07:09 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Thanks for the help, fellas. So in conclusion the corvette heads do not have better air flow characteristics but there is a performance gain due to a weight savings, right?
1990 Formula
Factory:WS6-TPI-305/Dual Cat/5 Speed.Aluminum Drive Shaft.
Old Jan 31, 2001 | 08:57 PM
87Z-ya's Avatar
The corvette heads are far superior to the 305 heads in flow. The 88 and up are even better then the 87's.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
