305/350 TPI intake.
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
305/350 TPI intake.
I heard that GM used the same intake for the 305TPI and the 350...is this true?
yes it is. They are the exact same. Only difference is injector size, 19lb/hr on 305s, 22lb/hr on 350s.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
MrJ is right! However, be aware that GM changed the intake in '88 due to the removal of the 9th (cold start) injector!! So if you have a pre-1988 TPI setup, you don't want to put a 1988 or older intake on there!!
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, 64cc Pocket Ported Worlds Product Sportsman-II heads, ported intake, comp cam, TPIS air foil, Adjustable Fuel Pressure Regulator, and 24 lb/hr SVO injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
Sanjay
Aug 12, 2015 03:41 PM
