Need some specs on a 91 L98.......
Old Feb 7, 2001 | 03:54 PM
Trevor 91 Formula
Guest
Posts: n/a
Just for comparison reasons I need to know
a) what is the stock compression ratio for a Speed Density L98? I heard anywhere from 9.3:1-9.7:1
b) what are the stock L98 cam specs? I have a new comp cam with these specs and want to know how much more radical I'm getting.
Lift @.050- .500 intake .510 Exhaust
duration- 210 intake 220 exhaust
lobe seperation- 114
This cam is recommended for my blower setup and is good to 5800rpm.
I need these numbers to plug into DD2000 too so I can get some comparisons. Thanks!
L98 w/ ATI ProCharger P600B 9psi, 2 core intercooler. (New L98 coming soon)
Pro-Built Stage 3 700-R4 w/ Continental 2400 stall TC
C5 wheels and tires.
92 Firebird Convertible- L03, 700-R4
Bone Stock
Me, my car and I
"Speed kills but it makes me feel alive" - White Zombie
Crazy street-racing idiot member of the All-Powerful Nor-Cal crew.
Old Feb 7, 2001 | 07:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've heard on here the speed density L98's got a bump in compression to 9.7:1 or so. The cam specs are in the cam tech article on here. Its 203/207, .413"/.428", 114 LSA, or so...
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 7, 2001 | 11:51 PM
Darrell's Avatar
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Here is the specs I have for 1991's
4.9L (VIN B) 9.5:1
5.0L (VIN E & F) 9.3:1
5.7L (VIN 7) 9.8:1
5.7L (VIN 8) 10.25:1
Darrell
1991 GTA L98
Canada
Old Feb 8, 2001 | 12:40 AM
Trevor 91 Formula
Guest
Posts: n/a
I think thhe VIN 8 number you just quoted are for the Corteve with 58cc heads if I'm not mistakes. I think Kevins numbers are what I'm looking for.
Old Feb 8, 2001 | 01:19 PM
Yelofvr's Avatar
9.8:1 sounds pretty high with cast iron heads for a factory setting, I never knew it was that high. Does GM require 92 octane for the 90-92 TPI F-bodies???
Does anyone know what the piston deck height was set at on these motors? Also the compressed head gasket thickness? Trying to figure what the stock "quench" height was.
Dave Zelinka
Old Feb 8, 2001 | 04:04 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
According to my 1991 GM shop manual for Firebirds, the L98 had 9.75:1 with 64cc heads. And yes, the manual recommends premium fuel. Oh, and all L98s have a VIN #8 in the 8th digit. There is no "7" to my knowledge.
Old Feb 8, 2001 | 05:52 PM
Kevin91Z's Avatar
GM has stated 92 octane or better in all its performance engines for as long as I remember. So of course its 92 octane for the 90-92 L98's, and 87-89 L98's, and 85-92 LB9's, too.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
