My TPI engine pic!!!
Old Feb 4, 2001 | 01:31 PM
FormulaGod's Avatar
Thanks to all you guys for the help. I finally have my new setup.
http://www.webphotos.com/member/5815/67058.jpg
"Restore decency in America. Ban rice!!"
Moderator at www.Lastgen.com check us out!!
Old Feb 4, 2001 | 02:21 PM
mirage2991's Avatar
looks cool!
How do you like those Edelbrock runners?
85 Z28, 355, edelbrock base, SLP runners (old style) 58mmTB, ported plenum, stock cam, fuel reg, TES headers, flowmaster, 3.73's, shift kit, MSD 6a, 305 hypertech chip (YUUUCK!) best prior intake mods: 14.6 @ 94, 2.02 60' temp: 78deg, 80% moist, on radials.
69SS, black, 3,73's, TH400, 402 BB, roller everything (solid 246@50 622 lift)+stud-guirdle, 67 Vette heads ported and o-ringed, about 10:1 cr KB pistons, should be done this summer, goals: 500hp and lots of fun
Old Feb 4, 2001 | 04:03 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Great! Now ditch that crappy hood insulation. Its costs about $20 new from the dealer. It will make a HUGE difference in appearance.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 6, 2001 | 02:14 AM
burnoutrpm's Avatar
cool its red i like it! was wondering where do you get the tb to airbox plastic pieces?
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Feb 6, 2001 | 11:42 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
How did you get your hood to open so wide?
Old Feb 7, 2001 | 01:24 AM
442guy's Avatar
where can i get my hands on the 90 degree elbow between the maf and throttle body?
Old Feb 7, 2001 | 07:48 AM
FormulaGod's Avatar
That isnt custom. It came w/all Formulas that had the TPI. Call your local pontiac dealer (not Chevy, theirs were different) and tehy should help you out
-paul
Old Feb 7, 2001 | 05:44 PM
Blade's Avatar
Personally I think it's *****. Yeah the runners painted red, are cool but all the wires and vacuum being red is just rice...
Old Feb 7, 2001 | 09:38 PM
FormulaGod's Avatar
BLADE:
Are you kidding? Mine is *****? Your TPI has pink runners and throttle plate with yellow plug wires sitting on chrome valve covers. That is the KING of rice.
Old Feb 8, 2001 | 03:51 PM
Tom Batts's Avatar
Old Feb 8, 2001 | 06:49 PM
Slow Iroc's Avatar
So....like someone else said, how do you like the edelbrock runners? Did you get the baseplate to?
Old Feb 8, 2001 | 07:25 PM
FormulaGod's Avatar
The Edelbrock Runners are obviously the best looking out there. Yes, i have the baseplate too. As far as performance wise, im not sure about how much difference they made cause i modded the engine all at once. Heads, cam, headers, rockers, base, runners, etc...Im getting a nasty lound sucking sound somewhere in there, and im not sure where its coming from. It seems like the base/runners mating area. Im not sure if i didnt tourque em down right or the casting is goofed up. I'll tell you guys as it comes along. But the good news is the car is running phenomenally. 386 hp TPI!! And its only a 355!!!!!!
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
