Stock TPI on ZZ4
Old Feb 9, 2001 | 11:29 PM
98_1LE's Avatar
Stock TPI on ZZ4
Will it flow enough air if cleaned up/port matched?
87 Formula 350 14.61@94.07 before 2OTL, TCI stall, Nitto's, tubular LCA's & panhard
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Feb 10, 2001 | 07:53 AM
Guest
Guest
Posts: n/a
Kevin has essentially the ZZ4 in his car, and his best is a 13.2. I know he had a ported plenum and stock runners, and I think a stock ported base. Im sure a few aftermarket parts cant hurt though.
Old Feb 10, 2001 | 12:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, with a ZZ4 cam, ported ZZ4 heads, SLP 1 5/8" headers, and ported stock TPI intake, I've run 13.20's @ 107 MPH, and put 285 HP and 380 TQ to the rear wheels on a dyno. Dont forget the ZZ4 heads dont have EGR passages, if emissions is a concern in your area.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 11, 2001 | 10:22 PM
86T/AWS6's Avatar
Kevin,,i was wondering what kind of das milage you get with the zz4 cam in your car,,,also do u burn your own chips or do u just use one as a universal?....thanx lata
86 Trans Am,T-Tops,305tpi,7r4(rebuilt w/shift improvments&added clutches,9-bolt(2:77:,flowmaster,3" cat back,,,otherwise completely stock
Old Feb 12, 2001 | 01:04 AM
Kevin91Z's Avatar
I get over 20 MPG on the highway, usually about 22-24. I have a friend who burns my chips. I only have to touch the WOT specs (more timing and fuel), as the idle and closed loops specs are fine.
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
