Need help with off idle stumble...
Car: 1991 Formula Firehawk (Clone)
Engine: 350 with Firehawk Package
...well, got the engine back together and in the car, new Trickflow 23 degree heads, SLP 51006 cam and 1:6 roller rockers installed. Port matched the heads and 58mm throttle body to the SLP t-ram intake, and installed a new SLP 600-800 over stock torque converter, new plugs and wires. The car now pulls extremely strong from 1500 rpm to the redline, but stumbles coming off of idle. Timing is dead on, all parameters look good and the computer is not throwing any codes. I'm thinking that maybe with the higher lift cam I'm not getting the proper vacuum at near idle rpms, and maybe need a new chip for it. Also wondering if I may have a bad injector, although you sure wouldn't think that the way it runs once the rpms come up. Anyone have any other ideas or areas to check.
TIA for your help...
jimb0
jimbo
Mosquito Coast F-Body Association (MCFBA)
1991 Formula SLP350
1999 Trans Am Firehawk
jimb0
jimbo
1991 Formula SLP350
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
jimbo,
If everything else is dead on then you have the dreaded 'off idle stumble' due to heads/cam and upgraded intake. Basically, your cam pulls less vacuum and therefore you are running rich at idle (checking your BLMs will confirm this). However, just off idle you will be lean. The fully upgraded intake allows a massive amount of air to rush into the engine. This requires a PROM change to fix. Only problem is ... I doubt that a standard PROM guy could fix it. Specifically...
1) You need to adjust certain portions of your lower VE table to decrease the amount of fuel at idle.
2) You need to INCREASE the pump shot table. This table is the table that acts like an accelerator pump on a carb.
I had symptoms similar to what you are talking about and eliminated them very easy through PROM changes. BTW - do you have Diacom or a scanner?
Tim
2)
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
2)
- Program your own PROMs!. Read my article to get started!
- Research and Experiment before asking questions.
- This is not a chip store. Go to the classifieds if you want someone to sell you a chip or give you a BIN.
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
jimbo,
Tim
2)
</font>
jimbo,
Tim
2)
</font>
Thanx...really appreciate the insight...
jimb0
