EGR question
Old Feb 13, 2001 | 10:56 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
EGR question
Would running the car without the EGR have anithing to do with emissions testing? I mean would my car pass inspection w/out EGR?
thanks
1990 Formula
Factory:WS6-TPI-305/Dual Cat/5 Speed,3.42 rear, Aluminum Drive Shaft.
Mods:SLP air foil,K&N Filter,All Accel ignition parts,Hypertech Thermomaster chip,Stat,Fan switch.Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch.
Weight delete:Back seat-backs,spare tire.
Near future plans:Some runs at Raceway Park for a time slip, After headers install.Before cam+heads mods.
Old Feb 13, 2001 | 11:20 PM
Guest
Guest
Posts: n/a
I have a car that passes without it. Really you can pass without anything if the car is tuned right. The cat is the most effective of all the emissions control devices though.
Old Feb 13, 2001 | 11:33 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
See, I'm new to the whole EFI/Emissions control thing. Also I live in NY(no problem) but my car is registered in PA(cheap ins.). I'm not sure how strict they are in PA.
My cats seem fine and my car got the sticker last april.
The thing I noticed is many people talk about mods that might or might not make a car un-inspectable. I'm just wondering cause I'm from the old school of thought(carbs and no 'puters).Getting the most performance from TPI, while retaining emissions, does have me intrigued.
[This message has been edited by PONTIMANIAC 90 (edited February 13, 2001).]
Old Feb 13, 2001 | 11:58 PM
Guest
Guest
Posts: n/a
Well what you usually run into is a car in a bad state of tune, or it fails visual. FI is much easier IMO to get to pass a sniffer test than a carbed car. It just has more accurate fuel control.
Old Feb 14, 2001 | 12:09 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
So basically what you are saying is that the EGR is not vital to inspection(sticker), considering the car is tuned well and w/all other emission stuff in good repair?
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
