IROCZZ3
Old Feb 13, 2001 | 09:12 PM
98_1LE's Avatar
IROCZZ3
I read in another post that you have the ZZ4 cam and stock prom. Any issues or problems with your combo?
87 Formula 350 14.61@94.07 before 2OTL, TCI stall, Nitto's, tubular LCA's & panhard
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Feb 14, 2001 | 05:28 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I have a custom prom now, but I used the stock prom for a long time and when I went in for the smog test. Overall driveability with the custom prom is much better, but I never had any problems either with the stock one...no stalling, no erratic idle, no codes, etc. It idled a little rough in the mornings but it was pretty smooth after it warmed up. I also raised the minimum air setting slightly higher because of the cam when I used the stock prom...it idled around 750 in drive. BTW, the times in the sig are with the custom prom.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Feb 14, 2001 | 01:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I used the ZZ4 cam and stock 305 5-speed PROM in my car too. It idled great and got good gas mileage. Then I used a custom PROM that changed the WOT values for more timing and fuel, but the idle stuff was untouched. This cam is great.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
