Start up problems
Old Aug 29, 2007 | 04:47 PM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
Start up problems
My 85 has some issues when i start it. When it is cold it will not start unless I open the throttle at least 3/4 open. Then it will start but it will run rough and need plenty of throttle to keep running. A lot of smoke comes out the exhaust and it smells like gas. After about 10 seconds it idles normal. If i turn it off and start it up within 10 seconds it will start normal. Anybody have this problem before, I am thinking its the cold start injector. I have no codes by the way.
Old Sep 1, 2007 | 06:47 PM
Car: 1985 Z/28
Engine: L98 Carbed
Re: Start up problems
how can I test the cold start injector?
Old Sep 1, 2007 | 08:14 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
What color is the smoke coming out of the exhaust?
Old Sep 1, 2007 | 10:00 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
It's probably not the cold start injector. It's probably muliple injectors on the motor leaking. Here's a quick test. Hook up a fuel pressure guage to the schader valve on the fuel rail. Run the car for a minutes and note the presurre should be around 36 to 44 running. Then shut the car off and watch the guage. If it drops to zero right away your injectors are leaking. Time for a new set.
Old Sep 3, 2007 | 07:08 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
It should be located in on the left side of the engine. facing forward.
Old Sep 3, 2007 | 08:08 PM
rick89formula's Avatar
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
check your fuel pressure regulator. I just changed this on mine because I was having the same problem with mine but a lot more drastic. Mine would take forever to start and when it did it ran rough and had black smoke out the exhaust. I checked the regulator and found it to be bad. Replaced it and now the car barely gets a crank in before it starts and it even runs smoother and seems to have a little more get up on take-off.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
