SUPERRAM ON STOCK INTAKE????
Old Aug 30, 2007 | 04:32 PM
nelson84's Avatar
Car: 84 vette 85 vette
Engine: 350 crossfire, 350 TPI
Transmission: both 700R4
Axle/Gears: 84 vette 3.07, 85 vette 3.54
If you install a superram plenum and runners on a stock TPI intake and use a stock throttle body will you see any HP gains?
I was told a superram is to much for a 350, so by leaving the stock intake, would this help?
Or should I install a TPI vortec intake with vortec heads and put the superram on top with a 52 mm throttle body?
Which cam would go with this setup?
Old Aug 30, 2007 | 11:07 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: SUPERRAM ON STOCK INTAKE????
The SuperRam runners are larger than the stock intake manifold, so there will be a mismatch. The SuperRam is not too big for a stock 350. It was designed as a replacement for stock and modified 350 engines. The camshaft depends on how radical you want to go. Too much cam will require a custom chip and tuning. Too little cam will not give you the power you want.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
PestilenceIV
Aug 20, 2015 02:33 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
