Please help! MAT wiring question
Old Aug 30, 2007 | 06:43 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
I recently discovered that the wiring to my manifold air temp sensor had been completely severed. I was able to locate the correct positive wire in the wiring harness, however here's my question: does the ground wire run to the ecm, or would I be ok just running a new wire to the grounding point on the back of the cylinder head? Thanks.
Old Aug 30, 2007 | 07:09 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: Please help! MAT wiring question
You might try using the wiring section at www.chevythunder.com. Good web site.
Old Aug 30, 2007 | 11:40 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
The website verified that the MAT sensor ground goes back to the ecm.
Thank you, scuzz.
as on the site:
TPS and MAT sensor ground, pin B5
link:
http://www.chevythunder.com/fuel%20i...0(ecm#1227730)
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Polo Z03
Sep 10, 2015 06:43 PM
89gtaforsale
Aug 24, 2015 09:32 PM
redmaroz
Aug 16, 2015 11:40 PM
