TPI plenum polishing!?
Old Feb 9, 2001 | 09:00 AM
leirch's Avatar
Ok,
I've seen a lot of posting about polished TPI setups. I was wondering if anybody could give some insight on to the procedures that were taken. I would like to polish my superram setup. Its completely stock and is very rough. Check out some pictures at the page in my sig.
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Feb 9, 2001 | 11:37 AM
WesTek's Avatar
I also plan to polish my system since I picked up the Aluminum Plenum Extension yesterday. It's a really rough texture.
I would assume that you use sand paper (coarse then finer and finer) first, then some kind of buffing compound followed by a coat of clear paint or powdercoat.
Old Feb 9, 2001 | 11:58 AM
theformula's Avatar
I have sent an in depth procedure I wrote
Westek email me for it
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 09, 2001).]
Old Feb 9, 2001 | 12:30 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Go here and look at the polishing articles:
http://members.aol.com/mmmm999/3rd-degree/tips/tips.htm
under the Buffing Aluminum section.
Greg Westphal
'87 IROC 305TPI/A4
Old Feb 13, 2001 | 01:03 PM
WesTek's Avatar
Thanks Ryan and Greg.
The project seems overwhelming but I'll try it. I'll start collecting the tools and plan on doing it during the summer.
Wes
Old Feb 13, 2001 | 01:37 PM
JETHROIROC's Avatar
There's also a procedure in the Tech section of this board.
Old Feb 16, 2001 | 04:21 PM
Desert86Roc's Avatar
Nevermind...it's not there right now.
[This message has been edited by Desert86Roc (edited February 16, 2001).]
MantyZ28
16
Dec 21, 2015 11:02 AM
gixxer92
Sep 1, 2015 04:32 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
