Cam recommendations for TPI.....
Old Feb 15, 2001 | 02:33 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
What would be the cam recommendations for this Tuned Port setup, it would be a daily driver, looking for around 350hp and have decent gas mileage, but respectable power.
Build up includes:
ZZ4 short block
Sportsman 200 angle plug heads with 64cc chambers
Stock '92 TPI ported intake/plenum.
Doug Thorley headers and cat back
A TPI specific cam
Oh yea, this is going into a truck.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Old Feb 15, 2001 | 02:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please see the cam tech article on this website, or search this board.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 15, 2001 | 04:15 PM
The ODB's Avatar
The camshaft I run is a specially designed Lingenfelter profile for TPI engines, and would suite your needs very well.
ODB
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Old Feb 15, 2001 | 05:46 PM
2QUIK6's Avatar
After reafding various posts for the last 3 hours, I think I've decided on the ZZ4 cam.
I will not be exceeding 5000rpms as this will not be going to the track but will be passing alot of cars on the freeway, so I don't need the added breathing over 5k, usually no more than 3500-4k rpms.
The ZZ4 looks very streetable yet still have plenty of low to mid torque with the stock TPI intake.
Any different opinions??
Old Feb 15, 2001 | 07:31 PM
Kevin91Z's Avatar
Good choice, thats what I ran. You can get one from www.sdpc2000.com for $100 right now.
Old Feb 15, 2001 | 10:50 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Im gona run a Lunati full roller nitrous cam. Its in their specialty cams section in the catalogue. Its gona put me in the 380hp and 420ft/lbs. range heres a post from the mfba boards i made about it
http://ubb.mfba.org/Forum7/HTML/000107.html
check it out, thats everything new im gona run on my car this year.
Old Feb 15, 2001 | 11:23 PM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88blkiroc:
</font>
You are planning to put that camshaft in a street driven 350 TPI car ?
The only way I see it working well is if you keep the nitrous flowing full time.
That is a racing cam.
Old Feb 16, 2001 | 09:34 AM
IrocStan's Avatar
That Lunati full roller seems pretty hairy for a TPI. The dur @ .050 seems excessive, and a 112+ LSA might be better than the 110 LSA because it will provide more intake vacume. I got a Comp Xtreme Energy HR w/ 218/224, .495/.503, and 112 LSA, and some people were telling me that that was too big for what my engine.
87 IROC 350
Mods: 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
Recent stuff: SSM sfc's, Homemade relocation brackets, Ported SLP runners, ported base, EGR!
Current/future projects: homemade torque arm, and 27x10 Hoosiers (need wheels!), and Prom Burning
Planning new engine build, possibly 383 w/ TFS 23*
Old Feb 16, 2001 | 10:45 AM
The ODB's Avatar
excactly. It's much more radical than the cam I run in my 383.
N/A runs 10.9 @124,
Old Feb 16, 2001 | 04:27 PM
3.1 firebird's Avatar
ODB those are some impressive times you have there, and it appears your cam is mild. How does that beast drive on the streets?
Old Feb 16, 2001 | 04:31 PM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 3.1 firebird:
ODB those are some impressive times you have there, and it appears your cam is mild. How does that beast drive on the streets?</font>
It drives just like it did when it was new and stock. I drive it from St Louis to Atanta regularly and it got 24mpg last trip.
It is an extremely mild cam that builds great cylinder pressure.
ODB
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
