'91 TPI Manifold base on '88 L98
Old Feb 16, 2001 | 03:51 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Will a '91 LB9 SD TPI base fir perfectly on a '88 L98 MAF TPI. I figured it owuld but thought I'd ask. Bolt angles the same?
TIA
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Feb 16, 2001 | 04:00 PM
cobrakiller1989's Avatar
It should, they are both center bolt heads
Old Feb 16, 2001 | 05:28 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
It should bolt on no problem.
Just make sure that the middle intake bolts are at the same angle, which they should be.
One thing i would check is that on the later model TPI engines (90-92 i think) gm changed something with those little tubes on the runners, not sure what but if you check like for parts, they are listed 85-89 and 90-92, so there is some difference.
Maybe not in the intake manifold though.
Hope all goes well.
'88 RS (originally 2.8)
New 350, .040 over, ported vette L98s, ported stock tpi.
Old 305 injectors & chip
TES headers, 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-yet to race
(Damn the 2.8!)
Old Feb 16, 2001 | 06:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The runners, TB, and plenum are 85-88 and 89-92. But the base is 85-86, and 87-92. An 88 and a 91 are the same base, same casting number.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1992rs/ss
Jan 31, 2025 05:10 PM
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
