Found bad intake plenum gasket. Now that I fixed it,I have a super loud intake hiss!
Old Aug 31, 2007 | 06:49 PM
eurostylin's Avatar
Thanks to everybodys help here, I tracked down my issue to a bad intake gasket on the plenum. I ripped everything apart, and I was really careful putting everything back together. I also blocked off my EGR valve while I had everything apart.
Now that I "fixed" it, I have a VERY loud hiss coming from the air intake. And there appears to be a TON of air suction. I have a k&n filter cone on the intake. It almost sounds like my diesel truck when the turbo's hissing. Its super loud.
Are these things supposed to do this, or did I mess something up
I also replaced the IAC when I had it apart. It was filthy and wouldn't move. When I put the new one in, I pushed the little rod thingy in, just like the instructions said.
I don't have a VSS, so I'm not sure if it will set itself or not. Could this be my hissing noise?
Old Aug 31, 2007 | 09:10 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Found bad intake plenum gasket. Now that I fixed it,I have a super loud intake hi
Sounds like you have a vacuum leak. You can use smoke, carb. cleaner or starting fluid and I know there are more and be very careful doing this. Spray some of the above around the intake and when the idle picks up, there is your leak.
Old Sep 1, 2007 | 10:02 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
That's the sound of a clean IAC and a manifold with no leaks! most likely.
Old Sep 1, 2007 | 03:33 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Let`s hope so, I only have experience with carbed cars so that limits my knowledge. RednGold86Z sounds like he knows what he is talking about, thanks.
Old Sep 1, 2007 | 04:36 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Mine sounds like a vacuum cleaner when running- is it a strong sucking noise or is it a high pitched hissing noise?
Old Sep 1, 2007 | 06:42 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
My car hisses really loud too with the K&N filter.
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Aug 17, 2015 02:00 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
