manifold coolant leak
i am looking for a mechanic to fix my 91 formula. he/she must be a business owner with knowledge of tpi systems. also must be close to the toms river area. any help would be greatly appreciated.
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I can't help you with looking for a mechanic (I'm one, but in FL), but if you have manifold leak, check the oil to make sure some coolant isn't getting into the oil. If it's a thick brown color, or if water drops are on the oil or dipstick, stop driving it. If you have, you might need a rebuild. Safest way to check is to do an oil change and check the oil. If it's discolored, running the engine is a no-no. coolant+oil=bad,bad,bad. A friend of mine had that problem. Just a thought.
FormulasOnly
Sep 10, 2015 09:07 PM
