How much hp do you get from porting the plenum and gasket matching?
Old Feb 14, 2001 | 08:10 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
How much hp do you get from simply removing the restrictions in the plenum?
Also when you gasket match the runners to the plenum/manifold, what is actually involved?
Finally, what are the best dremmel bits for porting all of this?
Thanks for the time
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
Old Feb 14, 2001 | 04:39 PM
Nitro Don's Avatar
about 2 years ago I ported the stock TPI
Plenum,runners and base.I put about 50+ hours into the porting.I also gasket matched everthing too.
I cant say how much HP I made,but there was a HUGE seat of the pants difference.
I used a dremel too,just use lots of WD40 to keep the bits from clogging with aluminum.
Nitro Don
[This message has been edited by Nitro Don (edited February 14, 2001).]
Old Feb 18, 2001 | 09:58 AM
The ODB's Avatar
You get a much bigger gain by port matching the exhaust and gaskets. There is terrible overlap of both exhaust flange and the gasket. An easy 20hp depending on how bad, the gasket brand, and header brand & size. The 20hp figure would be for fel-pro gaskets and TES headers.
mrestrictrplate
Sep 21, 2015 11:24 AM
Nick McCardle
Sep 10, 2015 08:36 PM
hdis2002
Sep 8, 2015 02:52 PM
