lb9 starting problem.
Old Sep 6, 2007 | 10:05 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
on a cold start it will crank for a long while, until i see the oil pressure gauge go up to about the middle, then it starts to turn over.. the car never did this until i had to change out the ecu. its from an 86 car, but i swapped the chips out.. any ideas why it cranks so long before it starts??
Old Sep 6, 2007 | 02:11 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Re: lb9 starting problem.
come on guys,, need some help here.. i checked all the fuses, non were blown, could it just be a fuel pump?
Old Sep 6, 2007 | 02:47 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
I used to have the problem, the car could take up to a minute on cold starts, and it would crank and it was firing, but it would sit there and sputter to life eventually. I put a new 67gph (future-needs =D) BBK Fuel Pump in, because the old one was shot, and bam, it generally fires up as soon as I turn the key.
Put a fuel pressure gauge on, and see what the cranking pressure (priming) is. When I had the old/bad pump, it was at 3 psi, and it wouldn't hold pressure. The priming pressure is supposed to be 47 psi.
If there's not a lot of pressure, then I'm thinking you have a bad fuel pump. Check your fuel filter, though.
You say that you swapped out the ECMs? That just confuses me as to the coincidence of this issue. Maybe that is a bad ECM?
Old Sep 6, 2007 | 03:16 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
thanx mp81, would i be able to install a 255lpg walbro pump on a mostly stock car (if it is the pump) because future plans include a procharger. and that was recommended on the power adder section for what i want to do. so my question is can i run a bigger pump before its needed? doing it twice would be silly.
Old Sep 6, 2007 | 03:20 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
My pump is the same as yours (as in 255 lph = 67 gph), and it's fine (I have minor mods to the engine, but it's still the LB9). The regulator is ultimately what controls how much pressure is "let into" the engine. It'll fit right in.
Old Sep 6, 2007 | 03:51 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Does that tell you anything? When did the Trans Ams go to a SD setup instead of a MAF? Get the right ECM for your car and I bet it runs fine.
Old Sep 6, 2007 | 03:59 PM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
i thought the maf systems were on 86-89 and 90- up were speed density? my 89s stock and its got the maf system
Old Sep 6, 2007 | 09:53 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
I mean, I was thinking the same thing as Slepewesel, fuel pumps generally don't just die instantly like that (well, not die, but dead enough). If you need to replace it eventually, you can do that whenever, but I never swapped ECMs in my car, and it was the pump.
And yes, SD came out in 1990, so his car is most likely MAF still.
But still, try a '89 T/A ECM and see what happens.
Old Sep 7, 2007 | 08:52 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
89 is maf 90-02 is sd.. ecm's are the same 86-89 just different proms. i am going to try to check the fuel pressure over the weekend. before i order a new copmuter.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
