Best way to remove filings after porting the plenum?
Old Feb 22, 2001 | 07:22 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
When I finish porting my plenum what is the best way to ensure that there are no little bits of aluminum still in it? I obviously don't want them getting in my engine.
Someone suggested petrol. What do you think?
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods due in March:
K&Ns
RAM Air
Air foil
AFPR
Hoping to get a couple of tenths with that lot
Old Feb 22, 2001 | 08:20 AM
98_1LE's Avatar
I ran mine through the dishwasher after blowing it out with compressed air. You may want to remove the MAT sensor (or relocate it) even though mine was not damaged.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Feb 22, 2001 | 11:22 AM
kevinc's Avatar
Car: 1982 Z28
The common published method for cleaning out blocks, heads, and other parts after machine work is with a brush and hot water with dishwashing detergent.
Scrub them out thoroughly, then use a garden hose to wash the stuff out. Do this 2x.
I then use an air hose to dry the part(s), and spray them down with Liquid Wrench to prevent surface rust. Rust isn't a concern w/ aluminum so the Liquid Wrench part may be avoided.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Feb 22, 2001 | 08:44 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
To get chips out of the base take the bottom pan off and the 4 massive 9/16" allen head plugs out and wash and blow out w/ air. Good time to get all the sludge & varnish that hides up in here out with some castrol superclean
Old Feb 24, 2001 | 01:27 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
High Pressure Car Wash.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Feb 25, 2001 | 11:30 PM
BenDoe's Avatar
i used my dads 1800psi pressure washer
Old Feb 25, 2001 | 11:41 PM
theformula's Avatar
Chuck, I'm cracking up imagining you pulling out your plenum along with your dinner plates out of the dishwasher lol
RMK, I used carb cleaner and sprayd with a hose. Then got a hairdryer to dry it out.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Vintageracer
Jan 10, 2020 05:33 PM
89fast5oh
Sep 27, 2015 09:04 PM
Magman
29
Sep 12, 2015 10:41 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
