quick afpr question
Old Sep 9, 2007 | 08:00 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
quick afpr question
if you throw an adjustable fpr on a bone stock 3rd gen, what is the highest pressure you would be able to get out of it?
do you have to hardwire the pump straight to the battery to get more pressure???
Old Sep 9, 2007 | 08:18 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: quick afpr question
I believe the stock pump will push 80psi. You could hardwire the pump and get slightly more pressure.
Why would you want to do this? You'll put unnecessary stress on the pump and injectors.
Old Sep 9, 2007 | 09:05 PM
bigchief's Avatar
because, i cant get more than stock pressure with my AFPR.........
Old Sep 9, 2007 | 09:17 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
But he is asking, why do you NEED more than stock pressure? If you do actually need it, the proper way to get it would probably be to get a different pump, instead of hacking things up and unnecessarily straining your OEM pump and injectors.
Old Sep 11, 2007 | 01:07 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
REMEMBER LEAN IS MEAN!
Old Sep 11, 2007 | 01:15 PM
bigchief's Avatar
oh sorry, i dont really NEED more pressure, but i have the 255lph walbro, (holley's version)
i just figured i should be able to get more than stock pressure with that pump and the afpr
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
