code 33 and 34 (MAF)
Old Sep 9, 2007 | 12:22 PM
blue_iroc_z28's Avatar
Car: 1987 pontiac trans am gta
Transmission: 5 speed
Axle/Gears: 3.43 posi
how can i have both codes? 33 is excessive airflow, and 34 is low air flow . so i dont know whats going on . i was looking at my MAF wires and one has a nick out of it ,its the black with a white stripe (ground i think) its just missing the outer coating and you can see the inside of the wire. do you think that it is enough to mess with it? thanks in advance
Old Sep 9, 2007 | 02:00 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Re: code 33 and 34 (MAF)
I cant say 100%, but Im pretty sure that the ECM stores codes even if they are not active at the time that you read the codes. So i wonder if sometimes its tripping the code 33 and other times its tripping the code 34, then showing you both. The black/white wire is the ground wire, and its worth fixing the insulation on it to see if thats the problem.
A bad MAF is possible but it was about $180 when i replaced mine, so check for other causes first
Old Sep 10, 2007 | 11:52 PM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
i had both those codes at one point check for vacume leaks, u can check the relays and if worst case might be the sensor, i had to replace mine
Old Sep 11, 2007 | 01:17 PM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
Mine was throwing a code 33 for the last 6+ months. I replaced my burn off and power relays for the MAF sensor, I haven't had 33 pop back up yet. That was 4 days ago. I am pestimistic though and expect it to pop back up at any time. Now I'm getting a code 13. O2 sensor/wiring issue, should be a simple fix.
My advice (mediocre experience), check wiring and relays before you start replacing $200 MAF units.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Mark_ZZ3
May 24, 2018 01:02 PM
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
