Oxygen Sensor on SLP Headers
Old Feb 24, 2001 | 12:39 AM
Raymond 5.7 89 Formula's Avatar
I put some SLP headers on my Formula a while back. Actually I had them put on and was wondering is my 02 sensor now located further back than stock? Should I have changed it? Can someone please refresh me on what the 02 sensor does? Thanks for any info.
[This message has been edited by Raymond 5.7 89 Formula (edited February 23, 2001).]
Old Feb 24, 2001 | 12:08 PM
theformula's Avatar
O2 sensor maintains 14:7 air fuel ratio.
Use a scanner, if it is operating fine then don't change it. I changed mine just for the hell of it when I did my SLP headers
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 27, 2001 | 11:45 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have had no problem with my O2 sensor as far as its location is concerned in my SLP headers. The sensor heets up fast and the ECM goes into closed loop mode quickly, as it should.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Feb 27, 2001 | 12:33 PM
theformula's Avatar
Same here. That is the most important thing.
If you notice it doesnt go into closed loop then you need a heated 02
Old Feb 28, 2001 | 01:50 AM
Just saw a article in Hot Rodding magazine seems they had a problem with the stock oxygen sensor with SLP headers in a Formula like mine.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
89fast5oh
Sep 8, 2015 09:55 AM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
