SLP T-RAM Dyno Numbers
Old Feb 17, 2001 | 08:49 PM
dlp's Avatar
dlp
I made a total of 6 pulls the first was the worst and the 6th was the best. I would have done more tuning/pulls but my time was up. The peak numbers are not as high as I was expecting, but I am pleased with the profile of the curves. The heads are out of the box trick flows, cam numbers are .488I, .509E, 214degreesI, 222degreesE, and 400 miles on new ZZ4 short block with approximately 9.6 to 1 C/R. Are these hp and trq numbers comparable to Super Ram numbers with equivalent heads,cam and C/R?
The dyno guy said they typically see 20 to 23% parasitic losses with automatic equiped cars. This equates to 360 to 375 hp and 435 to 450 ft pds of trq at the fly wheel.
Carburetor and F.I. Connection/ ECS DYNO www.carbconn.com 425.820.1871
Title: David 87 IROC
Run Date and Time: 2/17/01 1:58:52 PM
Acceleration from 3000 to 6000RPM
interval = 1OO RPM
Absolute barometric pressure/29.68Hg Vapor 0.21 in.Hg.
Intake air temp 61.1 f
Gear Ratio 45.33 RPM/Mph
Correction Factor 0.97 SAE
Time RPM POWER TORQUE
N/A 3000 N/A N/A
N/A 3100 N/A N/A
N/A 3200 N/A N/A
O.00 3100 203.9 345.4
0.26 3200 210.8 346.0
0.52 3300 217.3 345.9
0.78 3400 222.7 344.1
1.31 3600 237.2 346.0
1.57 3700 244.3 346.8
1.83 3800 248.2 343.1
2.09 3900 254.0 342.1
2.36 4000 259.9 341.3
2.62 4100 266.1 340.9
2.89 4200 270.3 338.0
3.16 4300 274.1 334.8
3.43 4400 278.7 332.7
3.70 4500 282.2 329.4
3.98 4600 283.5 323.7
4.26 4700 286.2 319.9
4.55 4800 287.9 315.0
4.84 4900 288.O 308.7
5.14 5000 288.7 303.2
5.44 5100 287.3 295.8
5.75 5200 286.1 288.9
6.07 5300 283.5 281.O
6.07 5400 N/A N/A
6.74 5500 278.8 266.2
7.09 5600 277.1 259.9
7.45 5700 274.4 252.8
7.81 5800 274.6 248.6
8.19 5900 272.4 242.5
8.19 6000 N/A N/A
Column Max
288.7 346.8
Column Min
203.9 242.5
Column Average
263.2 315.3
87 IROC -
ZZ4 350
SLP T-Ram,1"3/4 SLP headers, Cat back, Hotch-kis, MSD, Iebach etc.
[This message has been edited by dlp (edited February 17, 2001).]
Old Feb 19, 2001 | 08:18 AM
jimbo's Avatar
Car: 1991 Formula Firehawk (Clone)
Engine: 350 with Firehawk Package
...what size throttle body are you using? I'm running a 58mm on my t-ram, and found that the intake holes on the plenum were only 52mm...so I have opened them up. My last best dyno was was 291 hp with the t-ram, TFS twisted wedge heads, and a mild SLP cam. Just switched to the 23 degree heads, a more aggressive cam and did some port matching. After I replace the chip, I'll put it on the dyno again to see what she picked up...am hoping for around 310-320 at the rear wheels...
jimbo
Mosquito Coast F-Body Association (MCFBA)
1991 Formula SLP350
1999 Trans Am Firehawk
Old Feb 19, 2001 | 01:06 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Interesting numbers, almost deja-vue 8-)
My car has the hi-flo TPI, ZZ4 long block,
and LT4 HOT cam and pulled almost the
exact numbers..
http://www.eecis.udel.edu/~davis/z28...2/webpage.html
mike
Old Feb 19, 2001 | 01:41 PM
87Z-ya's Avatar
Good numbers for a 350!!!! I take it some computer tuning was done to it?
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Feb 19, 2001 | 07:53 PM
dlp's Avatar
dlp
Jimbo, its good to here from another T-RAM owner. Im using a hybrid Arizona speed and Marine T.B. 87 housing with 92 linkage cam. I haven't port matched the plenum to the tb yet. But because my transmission grenaded the day after dyno testing I have plenty of time now. I was hoping to fine tune on the dyno but spent most of the time chasing an extremly lean 17 to 1 A/F ratio. I had to set the TPS base voltage at .47 volts to get proper fuel enrichment at full throttle. It responded nicely on the 5th pull adding 30 hp across the board from 5 to 6000 RPM. I'm sure with a little more tuning and a fresh tranny it will put out about 300hp at the rear wheels.
87"zya I had a hyper crap chip (FREE BEE), then purchased a Ed Wright Fast Chip. Installing the Fast chip made a huge difference, but the $350.00 price tag was hard to swallow. I am learning that there is a lot of tuning that can be done with the stock sensor inputs.
85 Mike TPI - Yes, your numbers are similar, although it seems that the T-ram has a wider torque and hp band.
87 IROC -
ZZ4 350
Old Feb 19, 2001 | 10:27 PM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Nice numbers man I love that broad power curve.
I've got a 91 Formula, 350TPI, 1.6 rockers,no smog crap, mufflex 3.5 catback, underdrive pulleys, aluminum driveshaft, TCI street fighter trans with a 2200 stall, AS&M semi siemese runners w/ported plenum and base, AFPR set to 45psi, and a PR chip getting 7degrees of knock retard. 1/4mi=14.33@94 RWHP=261 RWTQ=345
Anyone else have numbers to compare?
Old Feb 19, 2001 | 10:38 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Wow, that's weird. I have the exact same dyno numbers as 91RamAir Formula, but with about 30* of knock retard (stock chip - being modified soon) and a much faster trap speed. I ran it for the first time yesterday, and only got one run in. After smoking the tires all the way through first gear (2.41 60' ) I ran a 14.2 @ 103 MPH. If I can get some traction I should be running a mid 13 I'm guessing.
Black 88 GTA L98
261 RWHP, 345 RWTQ
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Old Feb 19, 2001 | 11:53 PM
Greg90iroc's Avatar
i made 243 RWHP and 342 ftlbs at the rears. Granted it was not it track trim at the time of the dyno run. i ran a 13.62 @ 102 (this will improve a good bit this season). That was with the intake iced and my cold air setup installed and a few other track tricks. I am sure that if i ran octain booster and with my 1.6 roller rockers and the intake iced i would be close to 260 hp at the rears. We will find out here pretty soon.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
Old Feb 20, 2001 | 07:52 AM
85MikeTPI's Avatar
I was also curious, how are you all dyno'ing
your auto-trans cars? My dyno shop had
never did a non-BMW auto (where they can
turn off downshifts) and they ended up
unhooking my TV cable. I have since heard
that this is a "bad thing". Any tips?
My car consistantly turns 12.9 @ 106 ETs
and it seems I have equal/lower dyno numbers
from others posting here? I'm wondering if
the TV cable unhooked was causing lower
dyno numbers?
thanks
mike
My Z28, ZZ4swap, TPI EPROMs
Old Feb 20, 2001 | 09:11 AM
jimbo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 85MikeTPI:
dyno numbers?
thanks
mike
</font>
...the last dyno shop I used had me take it to the redline in 2nd gear...I didn't unlook anything.
Old Feb 20, 2001 | 09:31 PM
dlp's Avatar
dlp
85 Mike tpi- My runs were made in drive with the T-V cable unhooked. I think you may be correct that unhooking the T-V cable is a " BAD THING". I noticed the converter slipping alot while trying to lock up wich it never did on the street.
87 IROC -
ZZ4 350
Old Feb 21, 2001 | 03:52 PM
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
The 1/4 mi times were last year before the intake, AFPR, exhause, pulleys, d-shaft so hopefully will be in the 13's w/ some traction. I had a 2.02 60'.
When they dyno'd my car they ran through first and second easily and when the RPM's are above the downshift point they would nail it, usually when the converter locks up the dyno computer takes that as a shift and starts the run at like 3600 but once it did not detect the lockup and I made peak TQ @2600.
Old Feb 21, 2001 | 11:09 PM
87Z-ya's Avatar
It should be run in 3rd gear or whatever gear has 1-1 ratio. The tv cable should not be unhooked it lowers line pressure and is a good way to fry clutches. They should run it up pretty far in 2nd and tird should be where it is opened up to wot, the car should not kick down to second.
Old Feb 26, 2001 | 10:10 AM
Mike 25th's Avatar
Long live the T-Ram...
Lots of posts on here this week about the "T". Love to see it.
Just wanted to say hello to Dave + Jim and send this one back to the top...
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
One Awesome Camaro Site!
Old Feb 26, 2001 | 01:55 PM
jimbo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mike 25th:
</font>
Hi Mike!!!
Old Feb 27, 2001 | 04:27 PM
Steve87Pont's Avatar
Hey all,
Jim what have you done with the transmission? I'll be putting my T-Ram in this spring.
Old Feb 28, 2001 | 06:08 AM
jimbo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Steve87Pont:
Hey all,
</font>
...not too much...just an SLP 800 over stock converter and have an SLP shift recalibration kit I'm going to install after I get the new chip installed and baseline the car once more. The tranny has been performing well, and only has 14K miles on it, so for the time being I'm leaving it pretty much stock. I would, however, love to swap out my 10 bolt for a Dana 44 with a 3:54 gear. SLP has new ones for around $1600...have to save up a few more pennies for that one...
jimbo
1991 Formula SLP350
Old Feb 28, 2001 | 05:04 PM
I agree with you on that. Would love the Dana but the money is a little steep. I can't see how Ford sells the 8.8 for cheap and all th GM guys get is a choice between the 12 bolt or a (Dare I say it)Ford 9 inch. I have an older ('87 I say older cause I got it in 87 for my '82 TA)700R4 with a 3000 Art Carr non-lockup. I will probabally use until I can build up the stock one I have in the car right now. Lock-ups were removed in the past but things have changed.
Later
Linson
Oct 24, 2025 02:00 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Dragonsys
Sep 25, 2015 03:51 PM
