ported upper plenum
Old Sep 13, 2007 | 02:20 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ported upper plenum
OKay. I was searching for like an hour and didnt get exactly what I wanted. I read the tech article too already. I am thinking about siamesing my upper intake. Now can I do it with say a dotco tool to cut open themiddle walls, or should i use something else. Someone was talking about some tip, but is that used with a drill or what? lol i only know so many tools and things. Anyways if I just cut the the inner wlls and make them Siamesed, should I make the holes larger also? I Understand i wont gain much power, but its free for the most part. Thanx guys
Old Sep 14, 2007 | 01:06 PM
Mark 89Formula's Avatar
Re: ported upper plenum
Not familiar with a dotco tool but if it's like a Dremel it'll work. Sanding rolls are good for enlarging the diameter of the runner opening and you can use cut-off wheels to remove the divider between the runner openings.
The biggest improvement you can make to your plenum is to grind down the EGR bumps right behind the throttle body openings and blend the sides and bottom. You'll want to do this no matter what runners you use.
Old Sep 14, 2007 | 10:06 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay. ya a dotco is a cut off wheel for air compressors. Okay so i will soon cut off all those inner walls and get some sanding rolls. Thanx for the advice
Old Sep 17, 2007 | 08:41 AM
bigals87z28's Avatar
Car: Check The Sig
Its gunna be damn near impossible for you to cut the EGR walls that sit right after the opening of the TB with a cut-off wheel. You are gunna need some sort of dremmel or die grinder.
The bit to use has a cylindrical shape with little fins on it that go the whole length of the cylinder. Also as referd to as a "soda can with fins." I know that Home Depot has these near the Dremmel section. The walls should be first, then you can port match the intake using the gaskets, therefor giving you more room. If you want to siamese the runner holes, I would suggest you get runners that would take advantage of the added flow, but without them its kind of pointless.
Grind down the EGR walls right after the TB opening, then port match the runner openings.
Old Sep 17, 2007 | 02:30 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
okay. ill pick that up today. I was going to be buying new runners and a lower itake soon. I just wanted to do something while i aited around.
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
Reid Fleming
Oct 10, 2015 09:56 PM
