power increase with just heads...in general
Old Mar 1, 2001 | 09:55 PM
mirage2991's Avatar
what are the hp improvements you guys have seen by just geting better heads with the stock cam? gimme some ET's improvenemts if you have them...hp figure...sotp's...
Right now it would be easier for me to put a set of heads than change the cam...don't have a garage, and have not time....
85 Z28, 355, edelbrock base, SLP runners (old style) 58mmTB, ported plenum, stock cam, fuel reg, TES headers, flowmaster, 3.73's, shift kit, MSD 6a, 305 hypertech chip (YUUUCK!) best prior intake mods: 14.6 @ 94, 2.02 60' temp: 78deg, 80% moist, on radials.
69SS, black, 3,73's, TH400, 402 BB, roller everything (solid 246@50 622 lift)+stud-guirdle, 67 Vette heads ported and o-ringed, about 10:1 cr KB pistons, should be done this summer, goals: 500hp and lots of fun
Old Mar 3, 2001 | 01:53 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Probably 40 HP with AFR 190s, but you'll really need a cam change to take full advantage of their flow potential.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
bamaboy0323
Sep 3, 2015 06:07 AM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
ezobens
Aug 19, 2015 10:29 PM
forstral
Aug 19, 2015 03:20 PM
