TB concerns
Old Sep 14, 2007 | 07:57 AM
vetteboy86's Avatar
TB concerns
So I am wondering what I can do to get my motor some more air. I have a ported plenum with siamesed runners. I am still using the stock 48MM TB, so I am wondering if it would be worth it to put a 52MM on. I am looking at the numbers, and the stock maf will flow 658 cfm with screens removed. Is this the maximum flow through the unit, or the maximum it can calculate?
Old Sep 14, 2007 | 08:09 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: TB concerns
If you do a quick search, you will find that this has been discussed many times.
Nighthawkf-117
Sep 24, 2015 02:47 PM
apie2546
Sep 24, 2015 12:27 AM
skip91
Sep 22, 2015 10:25 AM
anesthes
Sep 18, 2015 12:34 PM
corey8084
Sep 17, 2015 02:56 PM
