85 TPI 305 to 350
Old Sep 15, 2007 | 12:49 AM
czbigboy's Avatar
Car: 85 IROC Z
85 TPI 305 to 350
Hi all. Can I use the 85 corvett ecm and knock sensor with my wiring harness? I am wanting to use about a 300 hp 350. I thought about the GM 350/290hp crate engine. Any ideas? I really dont want to change all the wiring out.
Old Sep 15, 2007 | 10:29 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: 85 TPI 305 to 350
Originally Posted by czbigboy
Hi all. Can I use the 85 corvett ecm and knock sensor with my wiring .
Yes you can,but why?-85 Vette have same ecm,esc module and knock sensor as your -85 f-body tpi.Prom is different than your 305 tpi prom.
Old Sep 15, 2007 | 11:26 PM
czbigboy's Avatar
Car: 85 IROC Z
I was just wondering how to get a 350 knock sensor for that year. I see everyone saying you have to change the sensor when you swap from 305 to 350. I dont want to start changing out wiring harness and stuff like that. I can rebuild the 305 but thought the 350 would be better.
Old Sep 28, 2007 | 01:32 AM
czbigboy's Avatar
Car: 85 IROC Z
Does anyone know what is the largest cam duration at .050 that can be use on stock computers for the 305 and 350 TPI motors? I am going with flat tappet hyd cam. My car is a 85'.
Old Oct 1, 2007 | 09:06 AM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
i was told to stay under 210 @ .050 with stock prom. but i used a slp 204/214 .420/.442 in my 305 and it ran ok with the stock chip i did change the chip later but it ran ok with the stock one
Old Oct 1, 2007 | 12:08 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Here is a link I found a while back that gave a quick overview of what is needed to swap froma 305 to 350. Not sure about your cam question though, sorry. For the most part though, the MAF cars can deal with the motor changes a bit better than the speed density ones.
http://tpiparts.net/305_tpi_to_350_tpi_conversion
Old Oct 1, 2007 | 03:21 PM
ChampionN84's Avatar
Car: 91 Camaro Z28
tpiparts.net are awesome at the harness conversions if needed. I had it done they are great!
Old Oct 7, 2007 | 02:15 AM
czbigboy's Avatar
Car: 85 IROC Z
Thanks for the info. I plan on using 350 shortblock from a local engine rebuild shop with flat top pistons. I have been looking at the Brodix IK 200 heads from Jegs. So using the vette prom chip and maybe the Crane Powermax 2040 cam, 2400 stall and 3.42 limitedslip, this thing should run pretty good for a daily driver.
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
