Cam, heads, intake for my TPI
Old Sep 16, 2007 | 05:04 AM
Allpro's Avatar
Hello.
I need som heads an cam for my Tpi.
Maybe I need a bigger inntake to.
Someone who can give me a hint about wich parts that will work together??
Syl heads, cam, inntake ,...
Vortec heads, but there are several different sizes of porting and chambers..
Please give me nr to summit or other sales places.
I live in Norway, nobody knows a s... about TPI here..
Visit www.verdal4x4.no to see my car
Old Sep 16, 2007 | 11:06 AM
Allpro's Avatar
Re: Cam, heads, intake for my TPI
No??
Old Sep 16, 2007 | 11:50 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
The best advice I can give you is to do a search or cruise around the message boards, see what other people are using and the results they are getting, then draw your own conclusions. There are lots of TPI engine upgrade parts on the market. Or, call JEG'S @ (800) 345-4545 / Summit @ (800) 630-3030 / AFR Cylinder Heads @ (661) 257-8124, or contact the sponsors of this board.
Bill
Old Sep 16, 2007 | 11:53 AM
Allpro's Avatar
Yes, I have done that...
But it is so many different solutions..
I would love if someone could tell me what they are using, and how it works..
Old Sep 16, 2007 | 12:04 PM
Burnout91's Avatar
Engine: Modded L98
I have not installed them yet, but I decided to go with AFR 195 Eliminator Cylinder heads, Comp Cams XFI268HR13 camshaft, Crane Gold 1.6:1 rocker arms, headers from Dyno Don (on this board), Pro-Built street / strip transmission rebuild kit and Edge 9.5" 2600 stall torque converter, for my next round of modifications. Current configuration is in my sig.
Bill
Old Sep 16, 2007 | 08:19 PM
jbpnumber03's Avatar
The best advice I can give you is to get a cam with a low RPM power range. Something that starts at 1,000 or so and goes to 5,000 or so. These cars are made to be torquey, not to make power at 6,000 rpms. if you get the vortec heads you have to get a special intake, and by the time you get the heads worked on to handle a good size lift, you could have bought a set of aluminum heads. dont waste the money on an intake unless you find one used for half price or so, port yours out. time consuming, but saves a lot of money. get some good runners and bigger injectors. headers. must have headers and anew y-pipe. good luck.
Old Sep 17, 2007 | 08:56 AM
bigals87z28's Avatar
Car: Check The Sig
First, what size engine?
What are you looking to do with the car? Drag race? Street/Strip? Just above stock?
How big is your budget?
There is just too much, especially for teh Small Block Chevy, to just shoot out a random combo. Without knowing that, there is no real way to figure out wtf you want to do.
Old Sep 17, 2007 | 09:28 AM
Allpro's Avatar
Chevy 350, put in a Toyota hilux.
Street/strpi and drag for fun.
Budget, so much it takes..
Today I have ported 305 heads, big valves, 252 comp cam, but this does not work!!
Original intake, and runners.
it has been burned a new chip, but I dont have any hp, it dont have any more to give at 3500 rpm..
I need something that works great. Good torq, around 350hp..
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
