Injectors Venom vs Accel - Which is better?
Old Sep 16, 2007 | 04:39 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I am looking through the Jegs catalog for some 36lb injectors.
Venom seem to be over $100 cheaper than the Accel.
Is there any real difference between the two or are the Accel worth the extra $$.
Is there a better third choice?
Bill
Old Sep 17, 2007 | 03:47 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Injectors Venom vs Accel - Which is better?
Bill
Yes - go with Fordmotorsport Injectors... they are available at Summit and (i think) Jegs. Don't waste your time with the Accel or Venom injectors... if you do a search, you will see that the majority of forum members have had problems with both Venom and Accel injectors.
Hope this helps.
I would also do a search to see what others (running a motor similar to yours) are using for injector size... 36# sound too big for a 305 TPI.
Just my 2 cents.
Last edited by formula_novice; Sep 17, 2007 at 03:51 PM. Reason: Automerged Doublepost
Old Sep 17, 2007 | 08:55 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
YES, use ford and not 36# way to big for the 305 with not
much done to it, Accel has new injectors out, early reports
that I have heard were a good inprovement but who knows,
so go with ford
Old Sep 18, 2007 | 03:29 PM
Car: 89 IROC
Thanks both.........I see 34lb and 39lb from Fordmotorsports. Probably go with the 34 though
I am pricing out how much to build my 383 hense me asking about the 36's.
Thanks again.
Old Sep 18, 2007 | 03:53 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
I put a set if accel injectors (26lbs) in my GTA and i haven't had any problems with them. I have heard a lot of people on this board put them down but i'm not sure they have even used them. I don't know how the Venom injectors are in a GM. I do know they never missed a beat in my toyota. IMO go with either brand and i think you will be happy.
Old Sep 18, 2007 | 05:21 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
I have 30# in my built 406 I program my own chips
dynod out at over 425 horse power without the NOS. I have a
150 hp shot, next time
tell us what your talking about, so we don't waste time trying
to help you.
Old Sep 18, 2007 | 11:53 PM
Car: 89 IROC
to help you.
1tpi,
I did tell you what I was talking about. I wanted to know about the difference between the two companies. I think you assumed it was for the engine in my car. I did not go into a complete breakdown on the engine I am looking at putting in my other car as I did not see the relevance. I appreciate your help though and did not see it as a waste of time..
Thanks again.....
Old Sep 19, 2007 | 12:47 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
1tpi,
Thanks again.....
The relevance, it's for a different engine thats not in your profile or
any place else
what would you have assumed, other people thought the samething,
it just makes it simple, thanks
Old Sep 24, 2007 | 04:12 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
I have 30# SVO injectors in my 412 with play left, depending what your doing to that 383 you can use anywere from 22# (very mild) and up.
I ran 24# in my old 383 and it was mild but had lots of play left with them 24#'s
The Ford SVO injectors are the only one's i'll recondmend
92-Formula
Dec 12, 2015 10:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
BAMiller
Sep 14, 2015 06:38 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
