SES light on highway, but NO codes?
Old Mar 4, 2001 | 05:00 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
As it says, what would cause this. It comes on and off but didn't throw any codes? It did throw a 22 once but why? The TPS is new and set right.
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Mar 6, 2001 | 01:00 PM
Steve89GTA's Avatar
Check your oil level
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Autometer Vac+Oil Temp
Old Mar 6, 2001 | 01:06 PM
james_fearn's Avatar
there's a post currently a several post down) titled "Dme up the wall!" by 88gta305 that states the same problem. I know many 3rd genners have this problem. You are not alone. I have the same problem although nothing is wrong with the car, no codes are thrown, and driveability isn't affected.
James
Old Mar 6, 2001 | 07:42 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
When we bought my son's 83Z the check engine light would come on while driving it but we didn't get any codes. We noticed a connector and short piece of wire lying on the passenger side frame but had no idea what it went to. While going through the GM shop manual I noticed that one of the emissions equipment notes included a computer memory power wire connected to the positive post of the batter. Sure enough, when we spliced a piece of wire to the connector/short wire we stopped getting a check engine light on the highway once the car warmed up, unless there was something wrong and then we would get a code. Without the memory power wire connected the computer "loses" its mind every time the engine shuts off and you get no codes.
Z's r Best
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
